After spending the night putting it in I ran into a few problems with this new trans.
And so far the one problem holding me back from driving the car is the fact that the housing over the tailshaft is different from the stock t-5. This is forcing the trans crosmember trans mount to be bent down. By the mounting bracket being forced down about an inch, it in turn raises the trans an inch with makes the trans rest against the body of the trans tunnel (after bolted to the trans crosmember). I dont know what to do.
Im thinking about getting the sawzaw or dremmel and slowely grinding the extra metal to allow the bracket to fit flush. Anyone think this is a bad idea. Iverall I am satisfied with the trans. Its noticably heavier than the stock t-5 though.
If there is anyone else on this board that has had a similar problem with a tremec let me know. It also kinda pulled my off guard when a couple of buddies were working on the car when I was at work so I wasn't there for the dissasembly of the crossmember peices. I will try and take a pic tommorrow before grinding anything down. Hopefully there is a simpler solution.
