Bad main bearing symptoms
65shlbycln
1,266
Atlanta
In the past few days, my 289 has started to run rough. When going through the revs, it almost sounds like a flat-4 out of a subaru.
I was told that my main bearings should be changed pretty soon.
Could this be what is causing the engine to run rough?
I had a turbo Buick that spun a main. It knocked under heavy load, not really any noise if just cruising. I guess the crank was supported by the next bearing except uder load it flex enough to knock. I babied it around for weeks until a rod fed by that main went south too. If it seems like a miss, it aint the bearing. If it souds like a jack hammer inside it is a bearing.
