OK, so I searched previous posts, found nothing. How can I tell if my motor mounts are bad? I have multiple suspension upgrades (springs, strut brace, etc...) Car is nearly impossible to shift smoothly and quietly. Changed to poly tran mount. No improvement, but the tranny noise does seem louder! I am thinkin loose rearend (3.55 were installed prior to my purchase), bad motor mounts, or bad Upper/Lower Contol Arms. I do like to drive like I stole it. THANKS
They arent too bad to change,they take some time tho,I had to pull the starter,loosen the mounts then using a floor jack and a block of wood to protect the oil pan,jack the motor up remove all bolts...take some muscle and and an 18" breaker bar with various extensions.The really fun part is installing the new ones and getting it all to line up properly
