bad starting
5oh H.O
when I first start my car when shes cold I can't touch the gas or she will shut off, I have to wait a little while then just touch the gas and ease into a rev, she then gets a little better as she gets warmer and when she do get warmed up it goes away, But the rpm's are goin up and down till the point where she almost shuts off. I cleaned the Iac (or watever its called) and still the same?
would this be a bad tps or is it likely something stupid like a loose connection?
Also what would be some good first mods to do too this car? I'd Like to add stuff to give me more power, but what about something for handeling? I think this car handles Like a turd. or maybe I just need new tires or some air in the ones I have now. lol
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
