I thought I had put my cooling system issues behind me but there appears to be something wrong still. Just to give you guys a timeline:
August: Replaced radiator, cooling fan, and thermostat
December: No heat coming from vents, fan stopped working causing overheating - had a complete coolant flush and discovered a bad ground wire from fan
February: Heats works for the most part, occasional periods where only cold air comes through the vents despite the car being above normal operating temp. Sometimes when I turn the heat on it will cause the temp to rise from the "O" in NORMAL to the "L" then all of a sudden it will go back down to the "O" after about a minute. This appears to be completely random so I don't know what the cause is. I should also mention that this sudden rise in temperature has happened without the heat turning on, but I figured the connection was worth mentioning since I have noticed the sudden rise immediately after I turn the heat on.
Any thoughts?
Any thoughts?
