Swede958 said:7. Install the hub. It comes already greased, I just put in a little bit extra cause, well, i wanted too. Tighten the spindle nut to 10ftlbs, loosen, then tighten again. Secure with castle thing and cotter pin. Oh yeah, dust cap too... I really hate putting those things on. What a PITA
The Swede
SoCal69GT said:Did you guys convert from front drums to the Baer system? Or stock discs to Baer? I was told that the Baer system will fit only on drum spindle. Is this true?
i think on 68-69, 70-73 spindles for the drums had a different bearing size then the prior years, also the attachment points where the caliper brackets attach.Route666 said:What's the difference between the drum and disc spindles?
streetgrande69 said:i think on 68-69, 70-73 spindles for the drums had a different bearing size then the prior years, also the attachment points where the caliper brackets attach.
Swede958 said:The pedal is still hard, I'm not gonna lie and say 'oh it's a snap to step on it". You gotta have a good right quad. But it seems to me the effort may be a bit more, but it get's more use out of it. I probable since driving (still with drum brake driving style) haven't pushed the pedal in more than about 2-3" past the slack.
For 4 wheel discs I might upgrade to a power set up, the early fox 2.3L booster works, just have to modify the firewall. Non power brakes are fine with me, less work for me to do. I've lived with them for 3 years, I can live with them with better ones for more.
That's a good idea for the exhaust piece 66hertzclone- I'll keeep it in mind.
streetgrande69 said:i think on 68-69 spindles for the drums had a different bearing size , also the attachment points where the caliper brackets attach are different the the drum spindle.
streetgrande69 said:oceanside, welcome! this is true, only drum spindles. i can tell yopu that drum spindles are easy to come by. if your in ocean side, go down to ecology and pull a set, i'm sure there are 4-5 sets out there. i know there were that many out in otey last weekend.
welcome.
