balancer question
  • Thread starter Thread starter red93fox
  • Start date Start date Nov 19, 2004
R
red93fox
41
  • Nov 19, 2004
im doing a head/cam swap and was wondering if i needed to mark anything when taking out the balancer? i pushed down the metal "marker" and scribed in a mark with a screw driver. was this even needed? or does it only go on in one position?
04sleeper
2,674
14
89
Dallas, TX
Nov 19, 2004
  • Nov 19, 2004
The balancer only can go on the crank one way. There is a keyway that lines it up for you. If you would like to highlight some timing marks now while it is off with some bright paint so it will make it easier to read when you set the timing then do it now.
You didn't have to scribe it though.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 19, 2004
  • Nov 19, 2004
Great idea by sleeper - I "detail" my balancers before installing. Clean, light sanding perimeter; spray bomb black satin. Let it dry, then using a toothpick, take silver enamel (Testors model paint works fine) and highlight the imprinted timing marks/lines/numbers. If you're not interested in doing the whole thing, simply highlight tdc, 10 degrees btdc, and the point you'd like to set it at - say 16 degrees btdc.
HISSIN50
34
129
Nov 19, 2004
  • Nov 19, 2004
those silver indelible markers work well too (on a black balancer) and are easy and quick (we can aspire to be as meticulous as Michael, but not all of us are).
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
