  • SN95 4.6L Mustang Tech
balancing tires
  • Thread starter Thread starter timeless2
  • Start date Start date Jul 18, 2005
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Jul 18, 2005
  • Jul 18, 2005
When getting tires balanced, does it make a difference where the weights are mounted (inside the rim out of view OR on the outside--visible to everyone)?
Mine came on the outside, stock, as I think I've heard the outside provides a better balance. True?
The weight mounts on my rims now (the little metal clips) are starting to pit a little and look nasty on the outside, like a tick on a dog.
I think inside would look a LOT better, but don't know which way to go.
MT1083
1,033
Charlotte, NC
Jul 18, 2005
  • Jul 18, 2005
I had tape weights put on the inside of mine. The clips are just too ugly.
ProCharger GT
153
Cleveland
Jul 18, 2005
  • Jul 18, 2005
It's true you get a little better balance with weights on inside and out - but you can also use tape weights that go on the inside of the rim (not the lip like the regular weights, but actually adhesive backed weights that go on the inside) that will give you a good balance as well. I would reccomend tape weights first.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 18, 2005
  • Jul 18, 2005
I got the tape weights. They are ok but they may still be visible depending on your type of rim. Also, check before you leave the tire shop. Twice I asked for tape weights and just got the regular ones...
timeless2
Admin Dude
202
154
the Shadow Gallery
Jul 18, 2005
  • Jul 18, 2005
Thanks, all. Does anyone have pics of tape weights?
I have the stock "Bullitt" style wheels, so do you think they will show badly?
How good does the tape weight hold up against the elements? I live in the snow/salt belt and plenty of heat in the summer, too.
2013 Geee T
805
Oak Park, CA
Jul 18, 2005
  • Jul 18, 2005
Ive always heard having the weights on the outside is better. I have the tape weights on the inside and have had balancing problems or at least I think they are balancing problems. I have to investigate further.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
Harmonic balancer wobble.
  • 2003 mustang gt modded
  • Dec 10, 2023
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2024
95BlueStallion
Progress Thread Komo's 1990 GT - Parts Gathering Purgatory & Home Remodel
  • gkomo
  • Sep 23, 2024
  • 104 105 106
2K
91K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 9, 2026
gkomo
Engine Bad engine shaking at idle
  • sav22rem22
  • Jan 2, 2024
6K
Fox 5.0 Mustang Tech Feb 2, 2024
sav22rem22
