ARBOC said:I have squeaky ball joints.
What do you all recomend?
I have prices on TRW ball joints. $75 canadian each.
The car is NOT lowered and everything is stock except the exhaust.
Dave14 said:Are you sure it is the ball joints that are squeeking? My car would squeek over every little bump and when I turned the wheel back and forth. Turned out to be the tie rod end. Much easier to replace that a ball joint too.
getting an alignment after replacing tie rods is not an option, it must be done and your driving should be extrememly limited before you get it lined up. when i do tie rods at work i drive it from my rack to the alignment lift and no more. i cannot stress this enough. even though you matched the threads i garauntee your toe is out, which could lead to serious tire damage. also a good a idea to replace both inner and outers while you are there.ARBOC said:You are so right. I took my car to work and jacked it up. It turns out to be the tie rod ends. I replaced the right side thinking that would fix it. It fixed part of the problem. The other side are wore out also. MAN WHY CAN"T I GET A BREAK!!!!!
So I got the left side ordered from ford and it will be here tomorrow. Should i get a wheel alignment too?
I also bought a throw out bearing and retainer to stop the squeaks under the car. Any advice for this one????? Should I grease up the reatainer shaft or the tranny input shaft?
bimmertech said:getting an alignment after replacing tie rods is not an option, it must be done and your driving should be extrememly limited before you get it lined up. when i do tie rods at work i drive it from my rack to the alignment lift and no more. i cannot stress this enough. even though you matched the threads i garauntee your toe is out, which could lead to serious tire damage. also a good a idea to replace both inner and outers while you are there.
all the bump steer kits i have seen include the outers only. as far as inners, this is the only time i will ever endorse the autozones of the world, but carquest sells replacement suspension parts made by moog which i consider to be of high quality.95strokerPSU said:Quick question, Steeda's bumpsteer kit replaces the outers only, right? Any suggestions on inners? just oem replacements?
tragikcomic said:Anyone happen to have a part number or a know of where to buy the A-arms with the balljoints already in them? I looked around and didn't see anything.
95strokerPSU said:I bought the 03 Cobra A-arms from www.oemfordparts.com. M-3075-D for $160 + shipping.
Swarzkopf said:I'm having the same squeeking over bumps/when I turn the wheel problem. It's LOUD and is getting worse. I had assume it was the ball joint, but now I'll look at the tie rod ends as well....in general, will a ball joint create these symptoms? Was I wrong in assuming it was the ball joint?
