Electrical Battery Drain, Yellow Solenoid Wire
ShallowGrave
371
Philadelphia
Had a battery draining issue in my 92 5.0 or a long time that started while it was sitting, and I've narrowed it down to the circuits that branch off from the Solenoid on the big yellow wire.
Assuming its the same as a 91 (whose wiring diagram I can find) the circuits that branch are as follows:
1. Ignition Switch
2. Fuse Panel
3. Window Defrost
4. Fuel Pump
I pulled all of the fuses to rule out number 2. Any ideas on the others?
