I need some ideas? My daughter's 65 4 dr Falcon keeps killing the battery after sitting for a few days. at first I thought it might be bad but the load tester says its actually in really good shape. So I disconnect the pos. cable and put a meter in line. Lo and behold I'm drawing 3.5 volts
I pulled each fuse to see if I could identify the offending circuit, got a 2 volt drp from the dome light fuse, but even with all the fuses and the radio pwer and memory disconnected I still pull 1.5 volts or slightly more????? Any ideas? One other thing when I found the 2 volts on the dome circuit I happened to hit the door switch & brake pedal, which gave an immediate 12 volt draw, but when I let off the pedal or pushed in the button the voltage took a minute or two to return to zero. Shouldn't it drop immediately. Help :?
