Battery question...
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Soon I'm going to be putting my battery in the hatch and I plan on doing installing a high-powered stereo in the vacant space where my rear seat was. My question is how do I put in another battery for the audio equipment and hook it up to the alternator like the other battery. I also plan to upgrade the alternator to a 130 or 200amp in the near future. Also, if anyone has any suggestions or experiences of how/where you routed your battery cable from the engine bay to the trunk i'd appreciate it! Thanks alot
--cj
You'd need to hook the batteries up in PARALLEL (positive to positive, negative to negative). Voltage will remain the same, but current will increase.
As for running the battery cable to the front of the car, I just ran mine underneath the carpet and then drilled a hole and ran it through the firewall.
Just curious, why are you putting the battery in your hatch? If it's to
gain a weight advantage, that stereo equipment is going to offset
any advantage you are going to get. If it's just to clean the under hood
up of the bulky battery, then by all means do it...just my .002....and just run the cable along the carpet on the drivers side and then through the firewall through a hole.....hope that helps....
Actually the stereo I'm putting in isn't that big of a setup... and I think I'm just going to stick with the one battery. The stereo is going in where the old rear seat used to be, so I don't see how it's going to be much of a difference as opposed to the weight of the car with the seat. I'd just rather have something good to listen to instead of a back seat (i hate driving people around)...
I've also seen people run the positive battery cable underneath the car and down the chassis of the car through a subframe connector... anyone ever do this?
Rear mounted battery ground wiring. Follow this plan and you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to the chassis ground where the battery was mounted up front. Use a 5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure that it the metal around the bolt is clean & shiny. This is the alternator power ground.
Crimp or even better, solder the lugs on the all the wire. The local auto stereo shop will have them if the auto parts store doesn't. Use some heat shrink tubing to cover the lugs and make things look nice.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground in the same place as you bolted the alternator power ground. This is an absolute don’t overlook it item for EFI cars
srothfuss said:
I believe that you will have to run them in series... But I have never done it so you should look it up.
To do it correctly, you need a battery isolator.
This will keep the batteries seperate, so that the main battery won't be drained along with the secondary - it also makes sure they each charge properly.
i really don't see why anyone would put the battery in the hatch at all unless you're running it only in drag and you only need the battery for small amounts of time (and if you're gunna' do that, you might as well just put magnetos in it). Ya'll have any idea how much voltage is lost for every foot of cable there is? lol its insane
