I got a question for you guys who built your own battery cables. How the hell did you guys crimp those connectors down ? The only tools I've seen to crimp battery lugs are like 150-300 dollars. I think this is a bit expensive just to be able to crimp battery lugs and terminals onto some heavy gauge wire. I don't want to use pre-terminated ends, what other choices are there ?
Yep, I agree. I went to a couple different napa stores. They did it for me. Also if you have any tractor supply companies, or diesel semi repair shops?? Check them. They cut them to my length, crimped, soldered, and shrink wrapped them for me. turned out nice.
You can see the switch. Since I am using a cell, I took the gas cap and neck out and turned a custom aluminum piece that bolted right in place of the neck.
joesgt281 - that is just some cheap automotive carpet I got at the local menards store.
I just bought a manual crimper for about $40. It looks like a little anvil and you position the terminal in it with the wire and hit it with a hammer. I used it on my relocation project with the welding cables and it worked very well. I got it at a local industrial supply store.
Coolest stealth one that I've seen is put through one of the backup lamps in the rear valance. Since the terminals would be exposed to rain at this point, I would think it would required some significant weatherproofing.
I've also seen it thru the taillamp, which eliminates the above problem, but not a method I am going to use.
I love the way you ran your wiring and fusebox... do you have a picture of your engine compartment? i am wanting to rewire my car and do stealth wiring on it as much as possible
I know you didn't ask me, but I thought I would throw this out.
I mounted all of my electronics to the divider board between the trunk and rear compartment. If you look at the pic I posted from the trunk side you can see the cut off switch and the solenoid (late model "falt version"). Now, look at this pic and you will see the back side. I mounted all of my electronics to a piece of lexan and mounted that to the divider board. If you look at the nut/bolt on the right side you will see how I grounded the starter solenoid. That is also the ground point for all of the electronics.
To access this panel all I have to do is remove four bolts from the mounts (you can see 2 of them in the trunk side pic) and the panel lays in the trunk for easy access.
I got a little creative. I used the clamp from one of those cheap tube flaring kists and the hammer end of a punch. Whacked it with a hammer and the crimps came out great. After the crimp I soldered and covered the connection with heat shrink
I talked to a guy at an alternator shop about 2 days ago, this guy really knew his stuff. He said that for any alternator making over 100amps to not even bother with criping. He said solder everything to make sure you are geting your money's worth out of the high amp alternators. So I guess soldering is the route for me.
