- Jun 2, 2004
- 978
- 0
- 0
do they fit into the 77 mustang II i car get a preped race ready rolling chassy cheap but i want a 460
shttygtstang said:do they fit into the 77 mustang II i car get a preped race ready rolling chassy cheap but i want a 460
Power Surge said:Anything fits with the proper modification. I have a 78 with a 5.4 in it, which is overall larger than a 460. Exhaust has to go out the fenderwells. If you plan to use a C6 you will need to make a new trans tunnel. How "race preped" is this car? If it's got a tube chassis nose then it should be easy. If it's a stock setup front end, you'll be doing a lot of fab work.
Any particular reason for the 460? You can build a big inch 351W based motor like a 415 or 427 (heck you can even go over 450 inches with an aftermarket block) that will make just as much power but be much easier to package in the car.
you will need to remove or at least shave the strut towers and install coilovers.
1badII said:Wow, that guy really knows his II's.
Power Surge said:Any particular reason for the 460? You can build a big inch 351W based motor like a 415 or 427 (heck you can even go over 450 inches with an aftermarket block) that will make just as much power but be much easier to package in the car.
COBRAIIW said:I called that guy on the car already,haven't had time to go see it yet.
Car has 8in. rear with 4:11's.
He says he used to have a C6 with a split bellhousing in it.
I asked if he modded the tunnel and he said it fit without enlarging.
No rollcage, does have a fuel cell.
Shttystang, are you near Conn.?
COBRAIIW said:I'm in Ansonia., I was going to look at the car this weekend but didn't have time.
If you seen it, what's it like?
I'd like to see that as well,74ProII said:I'd like to know how a c-6 fits unmodded? A c-4 with the 11" and change bell housinig won't clear without removing some material from the bellhousing, and forget about trying to take it out.
COBRAIIW said:I'd like to see that as well,
I just changed from a 4 speed to auto C4 and with headers,and THAT was tight!
Shttygtstang, I'm up near Emmet o'Brien, but not a Rich,or Daniel.
I'm also probably older than the guys you know.
I moved to Ansonia the first time in 1957.The second time in 2001.
