  • SN95 4.6L Mustang Tech
Bbk 75mm Tb
  • Thread starter Thread starter mustang2k
  • Start date Start date Oct 18, 2005
M
mustang2k
25
  • Oct 18, 2005
I just got done installing a TB. When I start the car it says tps sensor voltage is low. Does this mean i have to get a new tps?
sgarlic
3,085
Oct 18, 2005
  • Oct 18, 2005
Nah, it just needs adjustment.
This link has how to do it on the 5.0 and the 94/95's .. just happened to be the first link I saw.
http://www.muscularmustangs.com/tps.php
H
Hornetsnest
150
San Diego, CA
Oct 18, 2005
  • Oct 18, 2005
Do you have an aftermarket plenum or did you bolt it to the stock one?
M
mustang2k
25
  • Oct 18, 2005
I have an aftermarket plenum by MAC
hotmustang331
2,967
Bastrop,TX
Oct 18, 2005
  • Oct 18, 2005
Everyone has a problem with the TPS....but I installed a BBK 75MM TB about 6 months after my TF plenum....not one problem, idled just fine after install. Apparently you guys are jacking up the TPS when you remove it lol.
'03GTinFLA
486
St. Petersburg, FL
Oct 18, 2005
  • Oct 18, 2005
Loosen up the 2 bolts on the TPS, start car, move the TPS to the right or left, adjusting by ear, or voltage if you have a meter. There is very little room for adjustment, but it can make a difference. Then tighten. Hope it helps.
2gts4us, I beat you to this one.
M
mustang2k
25
  • Oct 18, 2005
Does this mean that I need a new one or can I move the screw around to see if I get any voltage which shouldnt matter
M
mustang2k
25
  • Oct 18, 2005
Wen i tighten it back up it just goes right back in its spot that i had it at? Or am i tightin to much?
M
mustang2k
25
  • Oct 18, 2005
M
mustang2k
25
#10
  • Oct 18, 2005
  • #10
I was wondering did u have to disconnect the negative and positive battery cables or just one? How long?
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 19, 2005
#11
  • Oct 19, 2005
  • #11
there is 2 bolts that holds TPS in place. u reinstalled it little off. So now your TPS is reading bit too low. So u need to get the TPS to 0.95+-.02 for your TPS to work correctly. when you losen those 2 bolts, u have ever so slight movement. u need to measure it as u move it.
after u get it right, u need to reset your PCM. after all is well, it'll idle funny for few days as PCM relearn your car
M
mustang2k
25
#12
  • Oct 19, 2005
  • #12
How long do I have to disconnected the battery cables?
hotmustang331
2,967
Bastrop,TX
Oct 19, 2005
#13
  • Oct 19, 2005
  • #13
Thrity minutes or so. the car will have a hard time idling and will run like crap.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Oct 19, 2005
#14
  • Oct 19, 2005
  • #14
30 seconds. Disconnect the neg cable and go into the car and place your foot on the brake petal for a few seconds to drain any possible caps holding charges etc.
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
