Oh, you're in for the ride of your life. BBK LT's are a great choice (Fitment, quality etc...), but they are no fun job, they WILL test your patience. Don't let this scare you though, they are WELL worth the effort, WELL WORTH IT. you could lift/pull the engine and kick, pull, pry, wrestle them in, but I noticed a much easier way:
Jack the car up (A decent height up, ALMOST as far as you can, but not that far), and place jacks on the frame rails underneath the car (About where the passengers feet would be). Remove the old exhaust. Loosen and remove the engine mount to frame nuts. Securley attatch a peice of wood (Short length of 2x4 will do fine) to your jack, and jack up the motor by the oil pan (about an ince or so, you may need to jack it up more). Slide the headers up from underneath the car and slip in the LT's. Take 2 exhaust bolts (per side) and install them at the ENDS of the header flanges. Drop the motor, put the motor mount bolts back in. Drop the gasket between the header and heads, then install the rest of the header bolts and tighten the bolts down (Lower the car if you need to). Install the Hpipe, and have fun.
