BBK Performance SSI Intake
  • Thread starter Thread starter del.5.0 lx
  • Start date Start date Apr 25, 2008
  • 3
First Prev 2 of 3 Next Last
mustangfan1990
505
Lenoir, North Carolina
Apr 27, 2008
#21
  • Apr 27, 2008
  • #21
ls1beater4eva said:
do your self a favor sell it and buy a holleysystemax intake or buy a tfs track heat if your planing on putting heads on too.I know i have heard nothing but bad things out of there intakes
on a NA car they suck ass and on nitrous they suck ass, BUT so far on a SC car they work great
ls1beater4eva
334
mooresville
Apr 27, 2008
#22
  • Apr 27, 2008
  • #22
now mustangfan how come i seen you coming back bragging on that intake lol jk na it seems to be good for sc cars but i aint been inpressed any other time with it
Maryland Stang
1,656
30
39
Greenville, NC
Apr 28, 2008
#23
  • Apr 28, 2008
  • #23
I'd like to see your exact list of parts before saying anything. We need to know everything. MAF/TB/heads/cam/tranny/rear gears/block... everything. You may simply have a classic case of some badly mismatched parts here. Bigger (especially intake manifold ports) isn't always better. If you have the stock heads then 19 pound injectors should be fine.
mustangfan1990
505
Apr 28, 2008
#24
  • Apr 28, 2008
  • #24
I aint braggin sucka lol I thought it was ****ty intake when I first got it and seen the power it was making. But when I got the SC put on there my tq numbers climbed FAST so I decided I would keep it. I have tried that intake on motor and it sucks and I have tried it on nitrous and it sucks but sc works well
mustangfan1990
505
Apr 28, 2008
#25
  • Apr 28, 2008
  • #25
He is right....and I dont care what BBK says they are just trying to cover their own ass. That intake would work well with stock heads and stock cam.....I have seen people go into mid 300s rwhp with a stock cam and I ma sure you can prolly go higher. Something isnt right with the intake not your engine....unless you messed with your engine and ****ed it up some how
D
del.5.0 lx
25
#26
  • Apr 28, 2008
  • #26
right now the car has under drive pulleys, equal length tube shortys,off road h pipe,2.5" flow masters' cold air ,3.55 gears i was told by the guy i got it from it also has a b303 cam,msd 8.5 wires msd coil, auto lite plugs(need to be p graded)
cobra r clutch,bbk quadrant,fire wall adjuster ,as far as the trans it's self i'm not sure other then it being a t-5
04gtboy
83
#27
  • Apr 28, 2008
  • #27
Ive got the BBK intake on my 345 hp Ford racing GT40 crate motor ! Love it over the Trickflow trackheat i had on it ! More bottom end power !The only issues i had was the upper hit my water tubes on the passanger side had to bend them a little ! I would get a spacer that goes between the upper & lower from summit to fix that issue .I didnt know they made one till after i was done . And i had a fuel leak to on the crossover tube and sanded the spacers down a little on the fuelrail mounts to make the orings seal when you tighten the mounting bolts !
D
del.5.0 lx
25
#28
  • Apr 28, 2008
  • #28
5spd GT said:
Your mechanic is wrong on more than one scenario there. Namely, the "too much air" comment and "not enough backpressure"...
Something was incorrectly replaced during the install.
Check vacuum lines, timing, plug wires, etc.
I talked to a friend on mine today & he said the same thing that it sounds like a vaccuum leak. & i told him i've checked & rechecked everything. He told me to pull the plugs. If theres oil on any of the threads of the spark plugs then i have an internal vacuum leak. so i pulled the plugs, cylinders 3 & 4 have oil on the threads. this means i have to pull the intake & check it for squareness. thats why i lost so much power.
vikingpower
656
CWU Ellensburg, WA
Apr 28, 2008
#29
  • Apr 28, 2008
  • #29
I recommend ARP intake manifold studs instead of bolts, the manifold will sit a lot more square when you install it
stykthyn
5,232
2,652
223
gainesville
Apr 29, 2008
#30
  • Apr 29, 2008
  • #30
good info right there
D
del.5.0 lx
25
#31
  • Apr 29, 2008
  • #31
thanks i'll do that
D
del.5.0 lx
25
#32
  • May 4, 2008
  • #32
changed intake gaskets yesterday and found that one of the tabs on the head gasket got bent durning first install,thats where the vacuum leak came from, now car has more powere.
what i dont understand is why the cam sounds more pronouced when all i changed was the gasket. sounds really good though! will be taking it to the track this friday to see what i gain.
Flavadave4
1,044
21
49
Utica, NY
May 5, 2008
#33
  • May 5, 2008
  • #33
So there was a mishap in the intial install?
I'll be interested to see what it runs this week, good luck!
69shocktower
173
21
39
Dakotas
May 5, 2008
#34
  • May 5, 2008
  • #34
Friggin fuel leak
Just got my call all together. Among other problems like it just wont start. GUESS WHAT, installed the thing just like BBK says to and the crossover tube still leaks gas. And its got to be the tightest designed thing around. Its nearly impossible to fit everything around it. Took 3-4 hours just to get everything right so it would go all the way down onto the lower manifold.
So back apart it comes again. Dont know what the heck im gonna do about the fuel leak since its installed to specks. Made sure that it was because of all the problems I heard about. Maybe Ill try sanding down the spacers like the other guy said. But it was already pretty tight on the O rings the way it is.
Im gonna do a seperate thread about the stupid trick flow parts.
mustangfan1990
505
May 5, 2008
#35
  • May 5, 2008
  • #35
I had problems too about mine leaking. What I did is before you put the spacers between the manifold and the fuel rail push the fuel rail together with the crossover tube and make sure all your injectors are all the way down if they are not it will be just a little cockeyed and it will leak. then slide the spacers in and it shouldnt leak. Also put some grease around the o-rings (just a little) to get them to slide in easy and make SURE that you dont rip them. They are REALLLLLY easy to rip and you will never get them to seal if you rip them
Ike83
St. Louis, Missouri
May 5, 2008
#36
  • May 5, 2008
  • #36
It almost seems as if the BBK intake has too many fitment issues. I almost bought one until the experts on this forum convinced me to stick with the Cobra. And let me tell ya, I am NOT dissappointed.
69shocktower
173
21
39
Dakotas
May 5, 2008
#37
  • May 5, 2008
  • #37
timing
So where did you end up timing it to? 10 is factory. Im pretty sure we tried the full range on the distributor. it could be that it flooded before we got it timed so thats why it didnt start. i doubt it will be that easy tho. Thanks!
D
del.5.0 lx
25
#38
  • May 5, 2008
  • #38
maybe your timing is off by a tooth this happen to me durning the second install.if you press the two fuel rails together with some auto silicone on the o-rings they should slide together tightly with no problem and not leak i have no leaks at all on mine.
the heater hose line is a little funny , i install an elbow in my intake then ran rubber heater hoses in place of the stock setup this gave me alot more room. now i did have to takke a little off the egr for it to fit,but other then that didnt have any problems
mustangfan1990
505
May 5, 2008
#39
  • May 5, 2008
  • #39
With my car on motor (before the supercharger) I was running 16 degrees of timing. Now I am running 10 degrees with the supercharger and that intkae makes GOOOD pwer numbers
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 6, 2008
#40
  • May 6, 2008
  • #40
just courious what kind of numbers are you making with what mods? peace
john
  • 3
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
