Beeping! Need Help!!
302-66
574
Waco, Tx.
Visit site
Today my 93 2.3 started something new, when you first start it and when you are cruising in od there is a beep that sounds like it is coming from behind the dash. It is not a beep like a door open or seat belt, but sounds like the beep when you hold a key on a keyboard down to long. It beeps once when you turn it on, and up to (mostly) five times at cruise. The only (good) idea I have had thrown my way is a charging system problem. Has anyone had this happen before? Any Ideals?
Thanks
Mike
  • Sponsors(?)
gtss
133
Airdrie,Alberta
Visit site
it is possible that it is a fault with your air bag system.
the systems are designed so if the warning light is not working then it will sound an audible beep as a warning to the driver that the air bag system is not working
hope it helps
gtss:canada:
ethangsmith
227
Manheim, PA
That is always a possibility. Some suggestions of mine:
Your front speakers are up on the dash, your radio could have some weird issue going on with it. Disconnect the radio and drive it around for a while.
Sometimes speedometers make weird noises. Mine will make odd noises occasionally.
The cowl trim could be rubbing or squeaking on the windshield. I have actually had this happen numerous times.
If you leave your fan on, it could be a squeak in the fan motor being funneled across inside the air duct.
Your car is infested with robots.
Jimmy2Times
63
Atlanta, GA
Visit site
I think gtss has the right answer... airbag system. Did your airbag light use to come on sometimes, and now it no longer does? It might be that you have an air bag fault and the light burned out and the beeping is a secondary warning system. I once temporarily disabled the air bag system on my crown vic and if I ran the car long enough while ignoring the air bag light, it would beep just like you describe. And it was loud enough to scare the crap out of me the first time it happened!
My other thought is did you or maybe a previous owner install an alarm system that might be having a fit?
bmadison
VA Beach
aftermarket alarm system could very well be the problem. if you don't have one, nevermind. but, i've installed several models that do a self test upon power-up and give audible beeps to indicate a bad zone or function. and would continue to do so while powered up. other than that i wouldn't have a clue. SRS issue sounds good to me.
302-66
574
Waco, Tx.
Visit site
Ok, Finally got my lazy butt off the couch and checked it out, it is coming from a blue box located behind the hvac controls. I know it is not the radio or alarm, but my blinker are not working, so I think it is them. I do not have a owners manuel, but the beeping stops when you pull fuse 18 out. What all does this fuse go to, and while were at it, what does 16 go to.
Thanks
Mike
RustBucket
585
Buford, GA
Visit site
Blue box? Beeping at startup? That's the airbag controller. If your airbag light isn't flashing. (It'll start flashing after the beeping quits), then the bulb may be blown. If that's not it, the controller has failed. I removed mine until I could find a replacement. Now the light stays on all the time, but it doesn't really bother me. There's an outfit on ebay that sells em, I just haven't bought one. I keep hoping to get lucky at a junkyard.
302-66
574
Waco, Tx.
Visit site
StangGT, thanks for the link, looks like I have found my problem.
So if I change the bulb the beeping will stop and the bulb will blink? I read that it is normally the clock spring, which would be ok. I too am about to sell my car ( need money for my 86) and want to get this fixed first.
RustBucket
585
Buford, GA
Visit site
Mine went from beeping to clicking.
The blinking light is actually a trouble code. Count the blinks. I think 6 blinks is a clock spring. Ten is an internal fuse fault in the controller. The fuse can't be replaced. You have to change the controller.
Thread starter Similar threads Forum Replies Date
justin82 Electrical interior beep beep noise Fox 5.0 Mustang Tech 9
TAJ Trunk Ajar Light Always On/double Horn Beep 2005 - 2009 Specific Tech 0
95Stangpa Beeping Noise? 1994 - 1995 Specific Tech 39
J ?? Non-stop Beep ?? SN95 4.6L Mustang Tech 1
Rodrigo Startup Beeps Changed Out Of Nowhere 2015+ (S550) Mustang -General/Talk 3
S 2014 Mustang Beeping 2005 - 2014 S-197 Mustang -General/Talk- 1
smmackie Electrical Random Beep After Start Up. Fox 5.0 Mustang Tech 6
bretamo 4 Beeps - Four Audible Reports From the Dash Fox 5.0 Mustang Tech 6
JhMustangGT03 Beeping noise after starting 03 GT SN95 4.6L Mustang Tech 5
B annoying beep Mustang Sound & Shine All 0
1993SSP Constant beeping/buzzer from under dash Fox 5.0 Mustang Tech 4
G Weird Beeping Sound Fox 5.0 Mustang Tech 14
RUNINAGT Beeping from dash??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
J beeping sound!!!!!!! 1996 - 2004 SN95 Mustang -General/Talk- 7
9646gt new pics of the ride and video..56k...wait for the beep 1996 - 2004 SN95 Mustang -General/Talk- 6
FOOT2DFLOOR Really annoying beep noise Fox 5.0 Mustang Tech 7
Blackone51 weird beeping noise when start car SN95 4.6L Mustang Tech 6
LarsD Horrendous beeping coming from my stereo Fox 5.0 Mustang Tech 7
T Adding reverse proximity beep feature 2005 - 2014 S-197 Mustang -General/Talk- 0
M seat belt noise beeping........HELP...! 1996 - 2004 SN95 Mustang -General/Talk- 4
dcurtis Beeping under dash? Fox 5.0 Mustang Tech 6
M Horn Beeps when going over bumps 1994 - 1995 Specific Tech 6
Grn92LX Beeping sound comming from behind the a/c controls?? Fox 5.0 Mustang Tech 20
screamin gt why won't the beeping stop? SN95 4.6L Mustang Tech 2
O Horn Beeps Twice When I Lock 2005 - 2009 Specific Tech 21
M seat belt beeping help SN95 4.6L Mustang Tech 4
S Instrument cluster chimes/beeps in reverse? 2005 - 2014 Specific V6 Tech 7
T 1990 question about a "beeping" Fox 5.0 Mustang Tech 6
J beeping behind radio Fox 5.0 Mustang Tech 2
Cantslowdown Horn beeps twice but both doors closed SN95 4.6L Mustang Tech 5
@ Wierd Beeping sound 1994 - 1995 Specific Tech 11
@ Wierd Beeping sound 1994 - 1995 Specific Tech 0
P Weird Beeping Noise From Under Dash?????? Fox 5.0 Mustang Tech 3
L annoy beeping noise Fox 5.0 Mustang Tech 3
S Weird Beeping Fox 5.0 Mustang Tech 9
K Annoying Beeping Noise! SN95 4.6L Mustang Tech 2
OrangeMustangGt My car beeps. 1994 - 1995 Specific Tech 3
J Beep! 2005 - 2014 S-197 Mustang -General/Talk- 8
S Beeps in reverse? 2005 - 2014 S-197 Mustang -General/Talk- 14
F Cursed Beeping 1994 - 1995 Specific Tech 9
5.0 Nostalgia How do I get the airbag beep to stop? Fox 5.0 Mustang Tech 8
Evenflow Whats the buzzing/beeping noise? SN95 4.6L Mustang Tech 4
A Installed new guages and now car is beeping at me... Fox 5.0 Mustang Tech 4
J Beeping sound.. Fox 5.0 Mustang Tech 5
Cobra1894 Blue Box Beeps Under the dash?? Fox 5.0 Mustang Tech 7
01MustangMan How do you turn the Seat-Belt Beeping Off??? SN95 4.6L Mustang Tech 20
D INTERIOR PIECES NEEDED The Welcome Wagon 0
D Suspension Griggs rear set up on my 1991 GT, need help with set-up Fox 5.0 Mustang Tech 1
mustangpauly 351w swap need help will not idle Digital Self-tuning Forum 8
T Need help identifying casting numbers 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
