Part 1: I plan on buying the Trick Flow Street Heat Kit ( Intake, Stage 1 Cam, Heads, Roller Rockers, Push Rods, and Timing Chain ) for my 95 Mustang GT when I get home from college. I also plan on getting a C&L 76mm mass air meter and BBK 75mm Throttle Body for my combo. My question is will those mods be too much for the stock transmission which is automatic and for the stock rearend? I have 3.73 gears and a Ford Racing Aluminum Drive shaft at home already waiting to be put on also.
Part 2: I would like to put my combo on a DSS 331 short block when I get the money, i was curious if those would work well together of if I should go with the AFR 185 and the performer Intake for the 331.
Please keep in mind this car is a daily driver and needs to pass Texas emissions test. Im not trying to make a drag racer, just a fun car to drive than can compete with the newer cars. Thank you for all your help and suggestions!
