how do you loosen the clutch? it's so hard to put in, like no one ever loosened it through time. I want mine soft
help me please
heh
help me please
heh
help me please
hehtomustang said:I want mine softhelp me please
heh
tomustang said:how do you loosen the clutch? it's so hard to put in, like no one ever loosened it through time. I want mine softhelp me please
heh
Keep stomping it intomustang said:how do you loosen the clutch? it's so hard to put in, like no one ever loosened it through time. I want mine softhelp me please
heh
are you a man or a mouse? More cheese?tomustang said:how do you loosen the clutch? it's so hard to put in, like no one ever loosened it through time. I want mine softhelp me please
heh
christiesledd said:there's a Ford clutch that is soft??![]()
tomustang said:actually alot of people have been telling me it's a bit too hard, i mean it is really tight. also i do have the TO bearing problem, think it's making it worse?
trinity_gt said:Like I said above, if the clutch really is abnormally hard to depress it could be the cable. It could also be that the car has an aftermarket clutch that has much stronger springs for more holding power. The release bearing won't make the clutch pedal hard to depress. Only if the sleeve it rides on (front bearing retainer on the transmission) is severely galled might you notice increased pedal effort. You'd notice a bad release bearing more from noise heard while the pedal was held to the floor (rumbling, squeeling etc) than anything else.
heh
