Bellhousing Q's
GrandeStang73
93
VA
I'm doing a T-5 swap on my 351C. I know a 302 T5 bell will bolt right up. Will a T45 do the same thing?? Only thing I cannot find is a Bellhousing for my transmission.... If you have one or know if anything else will work, LET ME KNOW......pleaseeeeeeeee. :bang: Always have to hit one brick wall, going to smoothly not too....:bang:
Correct me if Im wrong, but Yes it will bolt up. You will need a bellhousing/scattershield from an sn95 mustang. Foxbody bellhousing will not work because of the longer input shaft on the sn95(t45) trans.
Wait a second... after re-reading your post before I posted my response, what exactly are you trying to do? Are you trying to use the t45 bellhousing with the t5? In that case you will need either a t45, or the t5 used in the 94+ 3.8L mustangs (and dont worry, they still have the 3.35 first and are actually stronger than most of the earlier v8 t5s).
