- Dec 29, 2003
- 68
- 0
- 0
I have 1975 Tranny D50P-7006-AA. I need a 157 tooth bellhousing for it. Do they make a 157 tooth bell for this flair case tranny. If so who has one.
What did this transmission come from? Is it an automatic or standard transmission ?candyapple said:I have 1975 Tranny D50P-7006-AA. I need a 157 tooth bellhousing for it. Do they make a 157 tooth bell for this flair case tranny. If so who has one.
Go back on ebaymotors, there type in the " search"----- Ford Bellhousing. There's a guy there that has many C-4 bells for sale, and he "seems" to sound like he knows his ****. Email him and see what C-4 Bell you need and if he's got one. His feeback rating is 100%, so I would assume that he's good to deal with.candyapple said:Anybody out there got one. I need one ASAP. None on ebay
candyapple said:Someone send me this info. It is true and accurate.
"Even though it is pan fil,any 157T bell will bolt up except you use the pump bolts to fit it instead of the outer bolts on the larger case.You have to use longer pump bolts though to suit the extra thickness of the bellhousing.
