Belt slip?
  • Thread starter Thread starter VINMANCOCO
  • Start date Start date Jul 13, 2009
V
VINMANCOCO
newington, ct
Jul 13, 2009
  • Jul 13, 2009
Hey guys, new to the forum. Had a question, maybe you guys can shed some light on the situation. I have an 88 LX 5.0 with AFR heads, Comp Cam, and RPM II intake with a vortech t-trim. obviously all related fuel mods, etc. I have gotten to the point where the car will idle and drive great (without a tune at this point-coming very soon). I have a question about boost...car runs at about 5-6psi with the stock vortech 3.33 pulley. I was told that the set up would be running somewhere around 10psi. Just figured that my set was different and it was running a little lower. So to get to the 10psi that I originally wanted to run i dropped the pulley size down to a 2.95 (which based on vortech's site would be right about 10psi). Well after I installed the pulley, the thing is still running between 5-6psi. It does not make any sense to me at all. Could this be belt slip or am I missing something??? The belt is on pretty tight, and unfortunately a cog setup isn't in the budget (even though I want one BAD)...any help is appreciated, thanks.
88mustang92
105
  • Jul 13, 2009
are u using the same belt? if so shouldnt u downsize it due to smaller pulley?
V
VINMANCOCO
newington, ct
Jul 13, 2009
  • Jul 13, 2009
sorry should have clarified...smaller belt as well. designed to fit on the exact pullies i have...also bought from vortech
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
