Fox Bench Racing
  • Thread starter Thread starter RangerJoe
  • Start date Start date Sep 23, 2014
1 of 2 Next Last
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Sep 23, 2014
  • Sep 23, 2014
Ok, I know this is a little silly, but I have been debating with my brother-n-law over the weekend. He is doing a coyote swap now, but ran a 347 for years. I have a 331, and I always hear from him that I should have gone 347. So I asked him Sunday how much HP he thought his 347 made, he says 450fwhp (guesstimate).
I think he is a little high. Here was his combo:
347 at 10.5:1
Box stock tfs 170 heads
XE282HR
1 3/4 long tubes
Systemax intake with 70mm TB
So, what's the verdict? 450? More or less?
Personally I think my 331 will hang with his old 347 numbers (what ever they truly were). I will have a touch more compression, custom cam and the new AFR renegade 185 heads. Everything else will be the same.
Joe
elarm1
1,428
652
154
N.Va
Sep 23, 2014
  • Sep 23, 2014
My money is on you 331 spanking his Coyote whenever he gets done with it...
bentley429isBAC
922
188
84
CT
Sep 23, 2014
  • Sep 23, 2014
Way less. Sounds like 350 to the tire max. So maybe 400ish at the crank.
Reactions: FastDriver and hoopty5.0
RangerJoe
2,560
1,146
184
Georgia
Sep 24, 2014
  • Sep 24, 2014
Thanks for the confidence, but those coyotes are pretty bad. The biggest advantage his car has over mine is it's basically a race car on the street. Mine is pretty much full weight with AC, power steering and power brakes. He runs a 10.5" slick at the track and I run a 235 drag radial, so I know he will be faster, I just think the 347 wasn't as powerful as he thought.
That's about where I thought he was too, maybe 410 at the crank.
Joe
F
fordjunky
20+ Year Stangneter
Mar 25, 2003
29
Sep 24, 2014
  • Sep 24, 2014
RangerJoe said:
Ok, I know this is a little silly, but I have been debating with my brother-n-law over the weekend. ran a 347 for years.
I say he is a little high.
The combo I had in my hatchback street car had
372rwhp & 400rw torque.
Adding the standard 15% drive train loss for a manual transmission = 428hp-flywheel.
347
T5
Ported Cobra
6037 Edelbrock performers slightly ported
Off the shelf cam
Ran low 11s on Et-streets.
Yes it should "hang" since your comparing dyno #s.
The old 331 vs 347 debate has been done.
The 331 & 347 cost basically the same so its the buyers decision.
Mechanically speaking, the 331 "only" has to turn about 300 more rpms (per gear) to match the 347.
The buyer should ask there self if they believe in that "there is no replacement for displacement" or not.
ET wise they will be tit for tat if the vehicles there mounted in are basically set up the same.
ET wise I see your "new" combo ET between 12.5 to 11.8 depending on the 60ft & 118-125mph.
Other
Guys with the new 50 motor "in trucks" range in ET between high 11s to 15s.
A friend of mine ran 12.0s in a new full body mustang 50 with a programmer & exhaust on street radials.
RangerJoe
2,560
1,146
184
Georgia
Sep 24, 2014
  • Sep 24, 2014
@fordjunky
I ended up with the 331 because of my previous budget build and having to run iron heads (compression issues), so not really trying to debate the 331 vs 347, which is better argument, just more along the lines of which engine would theoretically make more HP.
The entire plan for this car since day 1 has been to have a nice driver that could make a trip to the track with the AC blowing cold, air the tires down, make an 11 second pass, and drive home. So I will be pleased with any thing sub 11.90 really. I know my car could benefit greatly from weight reduction and a set of slicks, but that's not really where I want to go with it.
I think he will get low 11's, maybe even a high 10 with his truck coyote by the time he is done. It should be interesting to watch.
Joe
F
fordjunky
20+ Year Stangneter
Mar 25, 2003
29
Sep 24, 2014
  • Sep 24, 2014
But you are.
This is part of the 331 vs 347 debate.
It depends on how you build the combo.
It depends on the parts used in the rotating assembly.
A 289 & 302 etc can make more HP than the 331 & 347.
All rotating assemblys pump air so
if you want to know which 1 rotating assembly will pump more air @ a "set rpm" between the all the available cubes (for the stock 302 block) between 289 to the 350, the 1 with the most stroke will pump more air.
RangerJoe
2,560
1,146
184
Georgia
Sep 25, 2014
  • Sep 25, 2014
fordjunky said:
But you are.
I wasn't intending an argument with you, but if you look at the actual question I posted:
"So, what's the verdict? 450? More or less?"
My real concern was whether or not he was making the HP he claimed, I just mentioned that he seems to think I screwed up by building a 331, whereas I think mine will make just as much if not more. Not based on the cubic inches, but based on parts selection (heads and cam mainly).
Please don't take my response wrong, I'm not one to get into internet arguments here, but I think everyone here, including you, did a good job of answering my question.
Thanks,
Joe
F
fordjunky
20+ Year Stangneter
Mar 25, 2003
29
Sep 25, 2014
  • Sep 25, 2014
Oh gotcha LoL.
I see now it was your bro-n-law that was making it more of a debate as he was just comparing the stroke alone as he said "you should built a 347 over the 331".
I say you both are correct to a extent in a basic statement.
Its like the saying goes "its not the size of the boat that matters, its the motion of the ocean that does" LoL.
Hind site wise you made your decision & he should respect it.
Looking at rotating assembly's in a physics manner makes it more interesting LoL.
Reactions: RangerJoe
Boosted92LX
5,721
4,244
224
Sep 25, 2014
#10
  • Sep 25, 2014
  • #10
I think people underestimate 347s. Look what edelbrock can do with them..
http://www.edelbrock.com/automotive/mc/crate-engines/ford-sb-main.shtml
Not plugging edelbrock, my point is, if that's possible, imagine some big afr or tfs heads.. I've got rpms on my car and plan on hitting it with about 9 psi.
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Sep 25, 2014
#11
  • Sep 25, 2014
  • #11
Had to put my shades on to look at those things, lots of chrome going on there.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 25, 2014
#12
  • Sep 25, 2014
  • #12
You speak as though everything in that link is 347 specific? All those goodies apply to the 331 as well.
Boosted92LX
5,721
4,244
224
Sep 25, 2014
#13
  • Sep 25, 2014
  • #13
hoopty5.0 said:
Had to put my shades on to look at those things, lots of chrome goingcomponentsere.
Yeah. A little shiny for my taste. But you gotta admit 500 hp is impressive for an n/a 302 based engine with edelbrock components. HP tv did an episode on them on a dyno. It was hard to imagine, but numbers don't lie. And I think there was a reason they didn't use a 331.
hoopty5.0
7,854
6,994
214
SW Houston
Sep 25, 2014
#14
  • Sep 25, 2014
  • #14
I always thought the 331 was better after reading this:
http://www.stangnet.com/mustang-forums/threads/302-stroker-information.719569/
Boosted92LX
5,721
4,244
224
Sep 25, 2014
#15
  • Sep 25, 2014
  • #15
I absolutely agree with everything there, Collin. Especially this:
331 (5.315"/5.400" rod) or 347 (5.315" rod) - Daily Driver
347 (5.400" rod) - Street/Strip or Track Car
For you, a 331 would make more sense. For someone like me who is going to roll it out of the garage on the weekend and trounce it, a 347 (or 363) isn't a bad choice.
F
fordjunky
20+ Year Stangneter
Mar 25, 2003
29
Sep 25, 2014
#16
  • Sep 25, 2014
  • #16
http://sbftech.com/index.php/topic,6087.0.html
hoopty5.0
7,854
6,994
214
SW Houston
Sep 25, 2014
#17
  • Sep 25, 2014
  • #17
link only works if you are a member there.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 25, 2014
#18
  • Sep 25, 2014
  • #18
Really.....what do you think that reason was?
If you've honestly convinced yourself that a 331 isn't as track capable as a 347, then no amount of date, or real world results are going to convince you otherwise.
My 331 is veeerrry rev happy. What SLIGHT amount of horsepower/torque it gives up to the additional 16ci offered by the 347, it more than makes up for in high RPM capability.
FWIW, a 331 makes for a better daily driver for longevity reasons, not because of performance limitation.
hoopty5.0
7,854
6,994
214
SW Houston
Sep 25, 2014
#19
  • Sep 25, 2014
  • #19
I didn't read that he said anywhere that a 347 is more capable. And while I wont assume I can speak for him, I wouldn't expect a response.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 25, 2014
#20
  • Sep 25, 2014
  • #20
Perhaps I misread it....but I was basing my response off of this breakdown. Not sure what other way there could be to take it?
1 of 2 Next Last
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
