I have to wait a few days till my Mechanic can look at my car he is very busy right now. I did take my car to a local place and they didnt diagnose the problem and curbed my rim but, thats a story posted already.
Anyways theres a grinding sound comming front the right rear when I press on the gas with medium or heavy torque it grinds.
If I apply light torque and hit a bump it will grind threw the bumps only.
When im coasting with low rpms and foot off gas and hit a bump no grind but if foot is on gas with light torque and hit a bump it will grind.
Im in no way a mechanic what do you think it could be if it was a wheel bearing it would do it more when I went around corners I think and it sounds more like Under car and not wheel related
I think it might be a axel but, as ive said I'm not a mechanic anyone else wanna guess at this.
BTW its a 94Gt 132K and lowered
a mini shock running from wheel area to chasis horizontally I looked like it was a small shock that would go in and out and has only moved 1/2 inch recently within this decaded
the rubber bushings on both sides of this device are squished and cracked thouroughly all the way around and dried out..
