rjstaaf said:I am not 100% sure about this but, most sources seem to indicate that the fluid flows from the tranny to the lower radiator connection and then up the radiator to the top connector and back to the transmission. This never made sense to me as I thought it would be better flowing down. Maybe the fluid would flow too fast through the cooler if it went from top to bottom![]()
You want to monitor the fluid temperature before the radiator on the bottom line and cool the fluid after it comes out of the radiator at the top line.
The quote below is from the A/T - Cooler Flushing Service Tips page for the 2001 Ford Mustang GT on www.alldata.com. I believe the data comes straight from the Ford service manual.
According to this info if you follow the top line from the transmission case to the transmission cooler in the radiator it confirms that the top line is the return line from the cooler to the transmission.
Maybe I am missing something on this, but in the diagram is shows that the top line(#1) is the fluid cooler inlet, and the bottom line (#2) is the fluid cooler outlet.....this would indicate to me that the fluid is in fact moving from the top to the bottom so the bottom line is the return line to the trans, therefore the one you would install the aux cooler in. What am I missing???
