Best auto tranny for mild 351
CarFreakGT
May 26, 2003
395
11
29
Louisville, KY
I'm looking for ideas/suggestions for an automatic tranny that will work well in my 68 coupe. The engine going in is a 351 making ~325 hp. The car will be an occasional driver, w/ a possible rare dragstrip run. TIA.
I'd run a C-4, but wanted to let you know a TH400 will fit. I couldn't find anyone with one in a 65-66 when I was trying to decide. Mu current build will be pushing the limits of a C4 and I know I will upgrade again at some point, so I made the jump to the TH400.
the sky is the limit depending on your budget. you can opt for a nice C4, all the way up to a modified 700r4(i think) that has six forward gears(you only need something like $7000 for one.). i would stick with a C4 or a built up AOD.
Depending on available cash you could get a gear vendors OD unit. I'm not a fan of the AOD as first gear is too high for my liking. But figure in the cost of the gear vendors unit you could possibly get a lower 1st gear for the AOD for less.
