Best Bang For My Buck :> $5,000
Suspension>power
I think my car handles good enough with just springs...:nice:
If I want to hook start hooking better on street tires then I will put my money into suspension.
1 autocross event I ran my times were only a second behind a modded 03/04 Cobra. And yes, the driver was very experienced.
+1 said beautifully
but what i would do is.........., do the pi swap to let the nitrous breathe a little better since you already have motor and continue spraying the non pi block until that retires. and in the meantime build up the 03 short block and just switch blocks and go with a bigger shot.
Sounds even better, lol.
I am also all for building up the suspension to get all your power you already have to the wheels, but i would also just build the 03 motor (forged), and up the spray. I'm a fan of nitrous because you DON'T have to use it all the time. You can whore someone n/a if you want and just use the nitrous when you want so if you do beat someone they can't say "well of course you won, you have a supercharger/turbo." That way if they want motor to motor, thats what they get. Plus keep in mind gas prices with forced induction are gonna suck.
OK Cart Update
Part # Item Price Qty Line Total Delete
AEI-13102 Fuel Pressure Regulator, 35-70 psi, Red Anodized, Ford/Mercury, Each $119.88 $119.88
BIG-12115FLT Headers, Full-Length, Steel, Painted, Ford, Mustang GT, 4.6L 2V SOHC, Pair $259.95 $259.95
FMS-M-6049-P46 Cylinder Head, High Performance, Aluminum, Assembled, 43cc Chamber, Ford, 4.6L, SOHC, Right Hand, Each $389.95 $389.95
FMS-M-6050-P46 Cylinder Head, High Performance, Aluminum, Assembled, 43cc Chamber, Ford, 4.6L, SOHC, Left Hand Side, Each $399.95 $399.95
FMS-M-6067-D46 Gaskets, Head Set, Ford, V8, Kit $117.95 $117.95
FMS-M-6675-D46 Oil Pan, Steel, Black, 5 qt., Stock Replacement, Ford, Mustang 1996-2004, 4.6L, SOHC/DOHC, Each $33.88 $33.88
FMS-M-9593-A302 Fuel Injectors, 24 lbs./hr., EV1-Type, Ford/Lincoln/Mercury, Set of 8 $289.95 $289.95
RNB-615-175 Intake Manifold, Plastic, Stock Replacement, Base, Ford/Lincoln/Mercury, Mustang GT 1999-2004, V8, 4.6L, Each $219.95 $219.95
SUM-227222 Throttle Body, 70mm, Aluminum, Satin, Ford, Mustang, 1996-2004, 4.6L, Each $159.95 $159.95
TFS-51811001 Intake Manifold, High Flow EFI, Upper, Aluminum, Black Powdercoated, Multi-Port, Ford, Mustang, 4.6L, 2V, Each $109.95 $109.95
Select All
If you have deleted any items from your cart or changed any quantities, please press the update button. Sub Total: $2,101.36
And I Want New Stuff Sorry I Am Just Wierd That Way
So basically a sprayed PI swap? That's a fun ride for sure.
Remeber you'll need
Gaskets: valve covers, intake, main seal, 3 timing cover
two heat stages cooler plugs
Alternator Bracket
Coolant pipe/hose to go over intake manifold
I still think you should find a nice used set of PI heads, get them cleaned up, throw some oversized valves at em and then consider transmission mods. And if you havent got a B&M tranny cooler add that to the list asap
Thanks Guys, Its just so hard to choose what to do and what will be the best. I am sorry I hope I havent got on you guys nerves but man it is so hard to pick what you wanta do when you finnally get the money. It like when you dont have the money you know exactlly what to do but when you get it you like ........ lol
And I Have Really 3 Options Other Than Just Motor
I Could:
1. Do Motor
2. Looks/Apperance
3. Drivetrain which would just be a tranny cause rear is done
I mean this aint the only time I am ever going to dip money in my car, SO HELP ME STANGNET LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pi intake/cams (if you dont have them) and a mongoose kit(around 4k) or a used kit (around 2500) and then suspension if you have anything left over, u can keep the spray aswell... you dont need to go pi, u just need to get blown :nice:
