Best cam bang for the buck?
I run the tfs stg 1 with 1.7's and afr 165's on the stock 91 shortblock with no problems. I've heard the performance gains from 1.7's is only like 5hp. I'm running them because i got them brand new and free from a friend.
squeeeg said:
do you have a stock bottom end. Did you check piston to valve clearence, if so how much room was there.
I was daring and did it. Stock bottom end with E7s, 1.78in, 1.55ex, not milled to my knowledge. I know I shouldn't flat out say it will work like that without having some measurements. In the end I took the 1.72s off since I felt there was no point lifting ported stock heads that high.
