best carbon cleaning method
jerry beach said:
Good post 90mustanggt. I imagine that the cleaner you use in the shop is similar the seafoam found at Napa. Follow the directions on the bottle and you cant go wrong with it. I have used water in a spray bottle, but never thought of the garden hose. I have poured tranny fliud down the TB too. My dad taught me that trick, it really smooths the idle on the old 289's that were designed to run leaded fuel. I have been told the tranny fliud can destroy your O2, but that was online and I dont know if there is any truth to it.
Thanks. The cleaner we use is pretty strong, it doubles as a paint remover, so it's pretty strong. BG products, I dont' think it is privatly sold. Works great though. Yes, tranny fluid works great also, and it can clogg the O2's also just like an engine that burbs a lot of oil. Tranny fluid is oil, but with additives, many cleaning agents.
GM sells a chemical called top engine cleaner. A cadillac mechanic friend told me about this because caddies are really sensitive to carbon buildup. Works the way people have described sea foam.
Running water (small drizzle or mist only!) into the intake while the car is running will clean the pistons. Not sure how long it takes to do that, but a blown head gasket will reveal a spotless piston and cylinder head.
