best catted X-Pipe?
The new 5 piece Bassani X uses their new "torpedo" style cats. These cats actually sit higher than did the cats on the stock H-pipe. PLUS, they're removable -- the kit comes with straight tubes to use at the track . . .
BLUE03GT said:
im currently running delta flow 40's, what catted x-pipe should i go with? anyone running a certain catted x-pipe with delta 40 flowmasters?
I have Delta 40's and magnaflow catted X is what I run and I can tell you its what you want. Sound is smooth with absolutely no rasp. It comes with cats taht are better than most of the others and all stainless steel. Order away.. try www.fulllineexhaust.com for a good price.. i got mine from www.partshopper.com
-wade
wms004 said:
I have Delta 40's and magnaflow catted X is what I run and I can tell you its what you want. -wade
Does the MagnaFlow Catted X-Pipe trip the check engine light or cause the system check to fail?
I want to run this pipe, but NY is going to an OBD-II test this year where they plug into your OBD-II diagnostic port and check all he sensors for complience.
i got the new 5 piece bassani with the new cats, the pipe and cats sit a tad higher than the original, ive got a bassani pipe on my 93 thats been on since early 99 and the cats havent gone out on it. i guess its hit and miss with bassanis cats
I would go Magnaflow. However I have the Bassani and the only issue I have with it is that it does kick the SES light on. It makes the power and has a good sound with the Magnaflow catback. Maybe some people have problems with it being too low, but mine isn't much different than stock.
I was going to get the Magnaflow catted X, but a buddy of mine had the Bassani on his 01 Cobra and decided to sell the car with just over 2000 miles on the odometer so I got the X pipe for half price. I couldn't pass that up.
My Bassani X pipe(with cats) set off my SES light...MIL eliminators fix that.
