im currently running delta flow 40's, what catted x-pipe should i go with? anyone running a certain catted x-pipe with delta 40 flowmasters?
sounds like a good plan..how is the fit ?damacman said:The new 5 piece Bassani X uses their new "torpedo" style cats. These cats actually sit higher than did the cats on the stock H-pipe. PLUS, they're removable -- the kit comes with straight tubes to use at the track . . .
I have Delta 40's and magnaflow catted X is what I run and I can tell you its what you want. Sound is smooth with absolutely no rasp. It comes with cats taht are better than most of the others and all stainless steel. Order away.. try www.fulllineexhaust.com for a good price.. i got mine from www.partshopper.comBLUE03GT said:im currently running delta flow 40's, what catted x-pipe should i go with? anyone running a certain catted x-pipe with delta 40 flowmasters?
wms004 said:I have Delta 40's and magnaflow catted X is what I run and I can tell you its what you want. -wade
tjm73 said:Does the MagnaFlow Catted X-Pipe trip the check engine light or cause the system check to fail?
I want to run this pipe, but NY is going to an OBD-II test this year where they plug into your OBD-II diagnostic port and check all he sensors for complience.
