Best Edelbrock Intake??
  • Thread starter Thread starter Mustang78
  • Start date Start date Apr 28, 2007
Mustang78
486
Aberdeen, WA
Apr 28, 2007
  • Apr 28, 2007
please post your opinions on the edelbrock intakes, and which is best for street/strip, i will only swing this 351 to 6000-6500RPM's Max...Torker II, Victor Jr.(hood clearance problems?) Thanks and any input is welcome, maybe you guys can convince me to buy a holley setup, BTW i already have a 650 edelbrock performer carb
~Mark~
jtfairlane
468
  • Apr 28, 2007
So this is for a carbureted intake?
If I were you, right off the bat I'd forget about the Torker II, that was one overall design by Edelbrock that never impressed anyone and under performs.
I can't tell you whether you'll have hood clearance problems with the Victor Jr. or not, but if you check out Edelbrock's website they give measurements for each of their intakes, so you could measure to find out if you have the room necessary. The Victor Jr. is a great intake for the strip, and if you will be doing more strip driving than street, that would probably be the way to go. It's a single plane, and will make more power up top (above, say, 4500-5000rpm) than any of Edelbrock's dual plane intakes.
However, if you are going to do more, or at least as much, street driving as you will strip, than I would highly recommend the Edelbrock RPM Air-Gap intake. It's a dual plane, and will kill the Victor Jr. in power numbers up to around 4500-5000rpm, and it's power band is 1500-6500rpm, right where you are going to be. It's got material removed between the intake runners, carb plenum, and the lifter valley to keep the incoming air cooler. I run one of these on my 289, and it is probably the best available dual plane intake for a high performance motor with a single carb.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 28, 2007
  • Apr 28, 2007
I have been asking myself the same question. Do I want to switch to a Vic jr? BTW for a dual Plane intake I recomend the Wiend Stealth. Its what I am running currently and with my nitrous and a set of Holley systemax II heads (165cc runners) I ran 11.5's. I want more but I'm not sure if sacrificing all the torque down low that is so much fun around town is worth it.
Mustang78
486
Aberdeen, WA
Apr 30, 2007
  • Apr 30, 2007
i love the look of the air gap but i dont want to have clearance problems with stock motor mounts and a 351w..i have the cutout hood and the pace car scoop so it should be ok..if not then im screwed, lol..so its between the air gap and weiand stealth, this is with an edelbrock 600-650 carb, is it really worth switching to a new holley carb and intake over edelbrock?? the local engine guy(hes porting my GT40s as we speak) says go holley...
~mark~
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 30, 2007
  • Apr 30, 2007
If you want to have to fiddle with your carb all the time go with holley. The edelbrock carb is a much nicer user friendly plug and play piece. I have a holley 750 on mine and it runs a bit rich. I don't mind that though because of the juice i run at the track.
jtfairlane
468
  • Apr 30, 2007
You "should not" have any clearance issues with the Air-Gap, it is not that much taller than a regular Performer RPM.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
F
Engine GT5.0 Intake vs. Edelbrock Performer RPM
  • Fox86
  • Nov 9, 2020
9K
Fox 5.0 Mustang Tech Dec 7, 2020
Fox86
F
