1992 2.3LX
forpit2000gt said:did you remove one of the studs and replace or remove a spacer from that side? if not you probably can't get anything to seal up. I really don't think this is a quality problem.
+1
That's my fault because i didn't buy an new gasket
. I have seen a shop in stall a magnaflow x w/ cats and it went in like clockwork and fitment was good.
That has to be a record or something.CaliLifeStyle said:No leaks with my Bassani X. Had a shop install it for me because I bought it from them and you know "since I'm here." They installed it in 15mins.That has to be a record or something.
V_Eight said:I did mine in 20 without ever doing one before, and by myself.![]()
four.six said:sure u did..... taking the starter off and everything huh??...![]()
streetstang03 said:why did you take the starter off to install a midpipe??![]()
cobra2798 said:I believe the magnaflow is a one piece pipe. Is your UPR bent or something? Mine dont leak and i reused the factiry gasket.
four.six said:i dont have a lift and it is so much easier to get to the bottom pass side manifold nut with the starter off... isn't that what everyone does??
