i have a upr o/r x pipe and have no problems with leaks where it bolts to the manifolds, but its leaking like crazy where it bolts to the factory pipes on the passenger side, i can see a gap between the metal, and i cant seem to get it out no matter what i do. im just gonna weld it up solid and be done with it.
The Mustang Tuning, Pypes, UPR and VRS X pipes all need a metal sleeve inserted into the LH inlet at the Header on 99-04 cars. If missing, the pipe will not seal properly. Anyone who is having sealing problems should confirm the sleeve is installed.
u did use the seal that came with the pipes for the passenger side right?? its like a 2 or 3 inch pipe. that is supposed to seal it. doesn't work very well, but its way better than with out it.
