Best front brake pads?
hotcobra03
poteet,tx
My 03 came with pbr pads.they are costly but ive found them very good.i have tryed motorcraft and wagner .they ok till high speed stops.when street racing they suck.the other problem is the round clips keep breaking loose and caliper has hit rim once.the ring holds everything tight .pbr ring will never spin anybody know of this problem and some pad options?
I don't know anything about the problem you are having because I've never done brakes myself. However, as far as what pads to get I recommend Hawk hps plus. They are squeaky and create a lot of brake dust, but they stop hard consistantly and won't fade or glaze over like the stock ones.
I can't speak for everyone or their app, but i've had Hawk HPS for 3000 mi now with no squeaking and the brake dust comparable to the stocks. As for the "Ring" are you talking about the C clip holding the lower caliper guide pin from sliding outward..? Or the clips holding the pads into their calipers..?
The 03 cobra brake set up is different.the brake pads hold the caliper . They have round ring that snaps into caliper.its a floating caliper.not concerned with dust or squeaks im look to find out if another aftermarket made like pbr.
