Best Suspension For A 1989 Convertible Gt 5.0?
  • Thread starter Thread starter derrick gil
  • Start date Start date Jul 20, 2013
derrick gil
67
Jul 20, 2013
  • Jul 20, 2013
What is the best suspension to put on a 1989 convertible GT 5.0? The stock suspension is a little lower in the back than the front, so it doesn't look just right. It should be a little higher in the back.
R
reldla1996
356
22
Dayton, Ohio
Jul 20, 2013
  • Jul 20, 2013
Best suspension for what purpose? What do you want it to do?
derrick gil
67
Jul 20, 2013
  • Jul 20, 2013
I just want it to sit right and ride good. It does have a 331 stroker in it, but I'm not drag racing it.
R
reldla1996
356
22
Dayton, Ohio
Jul 21, 2013
  • Jul 21, 2013
Sounds like you should check the front to make sure nothing has been changed, e.g. coil over springs, and if not just replace the springs in the rear with Factory springs. These cars sat level from the factory. You could also try some thicker spring isolators in the rear to space it up some. Maybe the rear springs were cut (or heated) somewhere along the way, and the spring iso's would make that up.
stykthyn
5,232
2,652
223
gainesville
Jul 21, 2013
  • Jul 21, 2013
poly spring isolators in the back. you can buy then in different thicknesses iirc. The stock rubber ones pancake over time.
derrick gil
67
Jul 21, 2013
  • Jul 21, 2013
Ok, I just ordered the spring isolators from energy suspension, and now I am looking at the Eibach Pro System Plus suspension kit from CJ Pony Parts. Is anyone familiar with this kit? Is it worth the money?
TOOLOW91
20+ Year Stangneter
8,709
234
S.I.NY
Jul 21, 2013
  • Jul 21, 2013
Forget the pro system. Make sure the bushings are in good order, and then get an eibach pro kit springs and tockico struts and i think that will make you pretty happy
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Jul 22, 2013
  • Jul 22, 2013
Sounds like you need new lowering springs, shocks & struts, and maybe some bushings here and there.
Reactions: toolow91
O
Paint and Body Has anyone put 1990 GT Hatch body kit on a 1989 GT Convertible
  • obeone66
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2025
General karthief
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
