Doing a gt40 manifold swap on my 88 gt. The manifold is off an early 97' explorer so it has the hole in the middle of the ports on lower. Just wondering what did everybody do to solve this problem other than just using the egr. thanks
If you still have the lower off the car then the fel pro 1250 intake gasket set has parts that block the EGR crossover at the cylinder head/intake manifold gasket. This is the best spot to block off the EGR gasses so that they do not enter the intake manifold and heat it up.
Other than that I tapped the EGR passage in the lower intake with for a 1/2" threaded plug and that worked just fine as well.
You need the [EGR] plate because the throttle cable mounts to it.
I was reading some old threads that said they used like rubber grommets or something but wouldnt that melt? I just kind of need something cheap to fix this little hold up. thanks for the respones.
RYC CUKR said:f you still have the lower off the car then the fel pro 1250 intake gasket set has parts that block the EGR crossover at the cylinder head/intake manifold gasket. This is the best spot to block off the EGR gasses so that they do not enter the intake manifold and heat it up.
Maryland Stang said:You need the plate because the throttle cable mounts to it
Maryland Stang said:you need the valve because exhaust gases will come out of the hole that it mounts into.
