BHP vs. HP
  • Thread starter Thread starter TheRedBlur
  • Start date Start date May 19, 2006
TheRedBlur
15
seattle
May 19, 2006
  • May 19, 2006
what's the difference, I know BHP stands for Brake Horsepower, but I don't get what that means. BHP is used in reference to engine power, not the brakes themselves. there, that's all I know, can anybody fill me in on the rest?
L
luckythirteen13
648
Anaheim, CA
May 20, 2006
  • May 20, 2006
usually you hear fwhp-fly wheel horse power and rwhp-rear wheel horse power. fwhp is the hp that the motor makes at the crank. rwhp is the hp that actually makes it to the wheels. there is a difference because the drive train (trans, diff, axles,etc) steal hp through heat and friction so the rwhp is always less then fwhp
big blue
132
lexington, ky
May 20, 2006
  • May 20, 2006
BHP was a European equivilant of HP. Both are extremely similar. The Brits use it all the time when listing a cars FWHP. They use a slightly different calulation than our SAE standards to measure a cars FWHP. I have found that it ranges in difference sometimes as little as 2-5 HP up to 15 hp. I take it for equal to our HP rating. Give or take.
88-GT
183
May 21, 2006
  • May 21, 2006
Yea its just in the way that it is measured. Its a rating for amount of work based on the torque. 1 HP = 33000 ft-lbs/min. All horsepower is is a value calculated from torque with rpm thrown in.
TheRedBlur
15
seattle
May 21, 2006
  • May 21, 2006
so BHP is like british horsepower?
sort of like how BTU is british thermal unit?
88convert
29
Indiana
May 21, 2006
  • May 21, 2006
Brake HP, as far as I know, is used in reference to electric motors. Electric motors have a name plate amprage i.e. 100 amps and also a service factor i.e. 1.15.- 2.0. Take the service factor times the rated amprage and that gives you the maximum current draw.
So in effect a 100 hp motor is capable of 115 hp MAX.
Brake hp is the difference between rated hp and the actual hp being used. Does that help?
K
klapdout
15
  • May 21, 2006
has nothing to do with british ratings its power at the driveshaft/hubs/wheels
heres definiton
brake horsepower
n. Abbr. bhp or b.hp.
The actual or useful horsepower of an engine, usually determined from the force exerted on a friction brake or dynamometer connected to the drive shaft.
TheRedBlur
15
seattle
May 21, 2006
  • May 21, 2006
ahhh, gotcha
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
