BHP vs. HP
TheRedBlur
15
seattle
what's the difference, I know BHP stands for Brake Horsepower, but I don't get what that means. BHP is used in reference to engine power, not the brakes themselves. there, that's all I know, can anybody fill me in on the rest?
usually you hear fwhp-fly wheel horse power and rwhp-rear wheel horse power. fwhp is the hp that the motor makes at the crank. rwhp is the hp that actually makes it to the wheels. there is a difference because the drive train (trans, diff, axles,etc) steal hp through heat and friction so the rwhp is always less then fwhp
BHP was a European equivilant of HP. Both are extremely similar. The Brits use it all the time when listing a cars FWHP. They use a slightly different calulation than our SAE standards to measure a cars FWHP. I have found that it ranges in difference sometimes as little as 2-5 HP up to 15 hp. I take it for equal to our HP rating. Give or take.
Yea its just in the way that it is measured. Its a rating for amount of work based on the torque. 1 HP = 33000 ft-lbs/min. All horsepower is is a value calculated from torque with rpm thrown in.
Brake HP, as far as I know, is used in reference to electric motors. Electric motors have a name plate amprage i.e. 100 amps and also a service factor i.e. 1.15.- 2.0. Take the service factor times the rated amprage and that gives you the maximum current draw.
So in effect a 100 hp motor is capable of 115 hp MAX.
Brake hp is the difference between rated hp and the actual hp being used. Does that help?
has nothing to do with british ratings its power at the driveshaft/hubs/wheels
heres definiton
brake horsepower
n. Abbr. bhp or b.hp.
The actual or useful horsepower of an engine, usually determined from the force exerted on a friction brake or dynamometer connected to the drive shaft.
