Big Air 90mm MAF Meter BA-2400
No you would have to get it re-tuned. Also, odds are the stock MAF is all you need. Do not waste your money.
You need to tell us your mods but the odds are that you do not need a different MAF.
brent_cosenza said:
My mass air meter is malfunctioning, and I wanted to upgrade the size anyways. Thats why I was wondering. My mods consist of Steeda CAI, 75mm Plenum and TB w/Spacers, 4.10 gears, FRPP Underdrive pulleys.
if you don't have close to 400rwhp, don't bother with the BA2400. you're resolution will be crappy as hell.
the computer reads 0-5 volts from the maf. normally, you want the voltage to peak in the 4 to 4.5 range. i'm peaking at about 3.75 volts with a little over 400rwhp. you'd see 2.5 volts at best.
