BIG AND WIDE
  • Thread starter Thread starter garistang
  • Start date Start date Apr 9, 2010
G
garistang
  • Apr 9, 2010
Hey Im fairly new to stang-net and I already love it, I have a 88 GT with 5 lug conv. Does anyone know if I can fit a 17x10 or 17x10.5 in the rear with minimal to no rolling of the lip? If possible, and also whats the biggest tire I can fit in there I would like to fit a 315/35/17 please help thanks in advance.
9
93luv
35
san antonio
Apr 10, 2010
  • Apr 10, 2010
i dont think 315 would fit without widening the wheel wells...
i got 17x9 with a 275/40zr/17 tire and theres less than half a inch
between tire and front part of wheel well...
you might be able to go to 285s but i dont know exactly how much wider in inches that is
stangbang302
180
fort valley, ga
Apr 10, 2010
  • Apr 10, 2010
285 vs 275 is not even close to an inch
9
93luv
35
san antonio
Apr 10, 2010
  • Apr 10, 2010
thank you for clarifiying...i know, its more like mm....
i meant just in general linear measurements.
7upstang91
936
124
74
Florida
Apr 11, 2010
  • Apr 11, 2010
You have to roll and bang the the crap out of the inner fenderwell. But a 315 will fit, a little cutting may be required.
281pony
2,681
Oly, WA
Apr 11, 2010
  • Apr 11, 2010
the biggest thing for you will be finding the right backspacing and offset. wheel replacement will play a huge part. you will need to roll fenders.
lancec2c30
570
Washington
Apr 12, 2010
  • Apr 12, 2010
Did you do ranger rear axles, or SN-95's and rear disk?
SN axles will push each side out 3/4 of an inch and make it next to impossible to fit a 10.5in wheel.
montyd
114
  • Apr 13, 2010
anyone know the right offset and backspacing ? id like to run a 315 also
lancec2c30
570
Washington
Apr 13, 2010
  • Apr 13, 2010
The easiest way you can do it if you are still 4 lug is to buy a set of SC style saleen wheels in 10.5. Put 315's on them, roll the fender lip, and start beating your inner fender with a BFH.
G
garistang
#10
  • Apr 14, 2010
  • #10
I did the 85 svo 5 lug swap and it came with stock 3:73s.
H
Haus
408
#11
  • Apr 14, 2010
  • #11
arent they a 7.5 inch rear?
lancec2c30
570
Washington
Apr 14, 2010
#12
  • Apr 14, 2010
  • #12
I think the SVO rear end is a tad wider then a stock fox setup too. I doubt you will be able to run a 10.5 wheel and tire setup.
G
garistang
#13
  • Apr 15, 2010
  • #13
yes your right, after doing some research I found out that the 85 svo's are 7.5. I just found out I was lied to by the previous owner. so I might have the ranger 5 lug? I'm going to have to check. thanks.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Tv kick down cable replacement 88 GT AOD
  • 5.0 HO
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 16, 2025
5.0 HO
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Drivetrain Can I use shorter than fox length axles?
  • silverlx50
  • Apr 18, 2022
Fox 5.0 Mustang Tech Apr 18, 2022
silverlx50
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
