SilverFox90 said:
yeah i knew it had nothing to do with displacement, so the only diff is the actual size of the block?...then why is it that most big blocks develop higher torque and are usually made to wrap less rpms than a small block...?
Big blocks have longer strokes. This increases their displacement and helps them make more torque. I have always ended up making almost every big block I have had knock
(400, 455 Pontiac, 455 Olds, and a 390, 460 Ford)
They dont like being spinned over 5k rpm most times.
On a side note I have never blown a 302 Ford or a 403 Olds
Trust I have tried.
When racing a big block you will usually see them walk like a mofo in 2nd gear and top end. Most small blocks can jump them out the hole or hang with them... but by the end of 2nd gear the big block will walk off.
Besides the big block having different size for the motor making it bigger and the longer stronger and large bore... almost all big blocks have great heads!
I'm talking large valves and intake and exhaust ports. On most small block motors you can stick say 3 fingers in the intake port for example. With big block heads you can stick your whole hand in some!
Good examples are the 428, 429, 460 CJ heads and the 351 Cleveland 4v head, all these from Ford have bad ass heads with huge ports and flow like crazy.
The Chevy 396/427/454 have huge ports!!!
Buick has the monster 455 and plus the block itself is very light weight for a big block.
Pontiac has the Ram Air IV heads
And Mopar has the Hemi heads and their wedge heads.
Most people dont realize that the old boss 302 motors use the 351 Cleveland 4v heads with a special intake
