Big Prob! Smog Pump Delete and ABS Motor
haulbalz
448
Well, last night, I tried to mount up my UPR Smog Pump Delete Pulley, and the pulley hits my abs motor! What do I do? I know it said some modification may be nessessary... But comon!
I'm not sure what exactly your talking about. is the pulley part hitting the abs module thing?
anyways the only modification mine requiered was some grinding on one edge of the block portion that bolts to the accessory bracket.
mine was the same as above, took the point off of the corner so it would recess all the way into the bracket.
i know some come with holes drille for the fox body, and some for the sn-95(both types of holes) not trying to say anything about you by any means, but do you have it mounted correctly?
screw it, why not just run a shorter belt, it's cheaper! I run a 90 on mine and it work great there is a diagram on here if you search to show the new route.
I run stock pullies with ac by the way
Dagz
