Big problem! Clutch or driveline, FIXED!!!
ok i have recently spent 6 years restoring a mustang. its a 1966 coupe with a mild 289 3 speed, 3.55 gears. everything is knew, i mean everything. So i have been driving it for about 400 miles now. Today i drove it for about 5 miles to my house then went to leave. when i hit the gas it was like it wasnt getting gas or was flooding out, basically it would fall on its face. so i drove it around a parking lot. it increases good slowly to 5 mph then the car starts physically bouncing, like it would go then bog down then go again, but with little change in the rpm. Here is the kicker when i push in the clutch or put it in netrual it revs to 4000 rpm very smoothly. so i drove it back to the storage shed 5 miles away, and noticed that in 3rd gear running about 2500 rpms it was like i was in a 5th gear going 20 mph (no throttle response, barely making it up hills like i have absolutely no power but i am still at good operating rpms). does anyone have any idea???? the clutch is new and was fine the first 400 miles or so, no problems. trans and rear are rebuilt and not making any noise. the car rolls in neutral so its not the brakes.
more background:
The clutch is adjusted to where you can shift after you push it about 3 inches from its resting position. when the car gets warm, and you are taking off from a stop the car shakes horribly unless you release the clutch fast and almost spin the tires. would having the clutch adjusted out like this cause this problem? how to i adjust it in?
So is it the clutch or do i look elsewhere? please help i need this car running.
ok i have recently spent 6 years restoring a mustang. its a 1966 coupe with a mild 289 3 speed, 3.55 gears. everything is knew, i mean everything. So i have been driving it for about 400 miles now. Today i drove it for about 5 miles to my house then went to leave. when i hit the gas it was like it wasnt getting gas or was flooding out, basically it would fall on its face. so i drove it around a parking lot. it increases good slowly to 5 mph then the car starts physically bouncing, like it would go then bog down then go again, but with little change in the rpm. Here is the kicker when i push in the clutch or put it in netrual it revs to 4000 rpm very smoothly. so i drove it back to the storage shed 5 miles away, and noticed that in 3rd gear running about 2500 rpms it was like i was in a 5th gear going 20 mph (no throttle response, barely making it up hills like i have absolutely no power but i am still at good operating rpms). does anyone have any idea???? the clutch is new and was fine the first 400 miles or so, no problems. trans and rear are rebuilt and not making any noise. the car rolls in neutral so its not the brakes.more background:
what kind of carb do you have?
