big problem removing computer! AODE to T5 swap guys...
skylovia
66
I cant figure out how to remove my computer!!! i have the stock Aode Computer in it now and i need to put in the t4m0 i just got. i got as far as accessing it. but the brass bolt that holds it in wont back out! it just keeps spinning in the hole! is there something i dont know? is it supposed to do that? PLEASE HELP!! it wont separate from the harness and im really frustrated!!!:bang:
It spins for quite a while, then you have to tug a bit to get the harness off of the computer. it's a long bolt that goes through the harness and into the computer. Don't bother trying to remove the bolt, just let it hang in the harness and remove it with that.
yeah, the bolt will not back out of the connecter. the whole connecter will "slowly" back off as you loosen the bolt. if you don't see the connecter backing off after a minute or so of loosening then it might be stripped and you will have to pull as you loosen as mentioned above.
