Biggest tire and rim on a fox?
TweekedGT
1,274
Alberta
Hey guys, I just got some weld 15x10 prostars and need to know if they will fit. I am quite sure they will but what size rubber can you put on them? The car has no exhaust and i'm going to take off the quad shocks because I have Lakewood traction bars and Maximum motorsport lower control arms and FRPP uppers. I cant test the rim because we've pulled the whole rearend out to change to 35 splines and a spool. What rubber should i get? Gonna be a pretty much full racecar with little street duty, even without the exhaust.
I'm pretty sure my 96 has a 4.5 backspacing and I run 315's on 10.5" rims and they don't stick out. What are most guys running that do 5 lug swaps? Don't you guys get just 5 bolt rims that fit the new style stangs? They don't stick out at all do they?
Both of these were taken from the americanmuscle.com website.
8" wheel has 5.72" backspace
Wheel Specifications
Style: Bullitt Finish: Chrome
Size: 17x8 Centercap Size: Large (2-1/2")
Back Spacing: 5.72" (145mm) Offset: +30mm (1.18")
Bolt Pattern: 5x4.5" (5x114.3mm) Fitment: 94-04 V6, GT, Bullitt,
Mach 1, and Cobra
10" wheel has 6.3" backspace
Size: 18x10 Centercap Size: Large (2-1/2")
Back Spacing: 6.3" (161mm) Offset: +22mm (0.9")
