biggjdogg headers good or bad?
They don't mention if they are also coated on the inside, which is crucial. They are conveniently turned over in the pics so you can't see inside. I'd be cautious, you usually get what you pay for when it comes to ceramic coatings.
WHITE94COBRA said:
Look how thin the flange is on those!!!!!! those things will warp faster than my mind on a 8 ball of crack......
3/8" flange is the same thickness as BBK header flanges. Mine haven't warped. I'd say go ahead get 'em if you want. :SNSign:
EDIT: Headers are pretty worthless without the rest of the exhaust being replaced. The 4 catted H-pipe is the real flow restrictor in the exhaust setup. If you aren't doing the whole exhaust at once I highly suggest starting with replacing the H-pipe.
Don't know which headers, but:
Good and fast shipping but problem with the fit of headers. Made fit.
Buyer heald4406( 0 )
Sep-01-06 10:27 Private
Reply by biggjdogg: Everyone that has ever installed headers know they are 95% time not direct fit?
Customer service looks a little "iffy" as well.
well, I went and bought it, I will do a review with pics after I receive the headers
I am doing the whole system with spintech side draft exhaust, I need a new system to go with this New Kenne Bell I have coming
Sweet.... definately keep us posted. Do you have a rough time frame on when you plan to install them? I'm sure adding the Kenne Bell will bring rav header results. :D
I had planned on buying the Summit shortys, these would be a lot cheaper. Really interested to see the quality of the welds on the inside of the flange. Seen a pair similar at a Street Machine Nationals tent last year. The welds were a little poopy. Rewelding would mean getting them coated again. :(
Looking at mid week next week to get the headers, I will include in depth pics and detail, Not sure yet as when I will install the KB,I have to come up with a few more parts still , Like the 42lb injectors ,90MAF and new fuel pump, Then Retune
I just received the headers today, all looks good so far. The header install sheet says WYSCO on it, http://www.wysco.com/autoparts/autoparts-04.asp
this is what pulls up on Wysco...
anyway here are a few pics, Welds all look good, Plating looks to be nice and thick,Flang is VERY thick and straight, and the inside looks to be coated also, I only found one area I didn't like a small ding on one tubes, It may of been from shipping but I doubt it cause headers were packaged pretty solid
