  • 1994 - 1995 Specific Tech
BIGTIME milkshake!!
  • Thread starter Thread starter CManT1914
  • Start date Start date Jul 24, 2005
CManT1914
3,172
Killeen, Texas
Jul 24, 2005
  • Jul 24, 2005
Well I drained my oil and a CRAPload of antifreeze came out. I won't have time to change the headgaskets this weekend before I go to the coast, so it will be next weekend before I get around to it. Looks like I might have blown both, for the first few seconds all that came out of the oilpan was coolant. At least maybe I found my problem. I'll let you guys know what else I find.
DFG 5OH
1,341
Louisville, KY
Jul 24, 2005
  • Jul 24, 2005
damn man...i hope everything works out
RIO5.0
6,892
N.H.
Jul 24, 2005
  • Jul 24, 2005
Damn....That sucks...
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 24, 2005
  • Jul 24, 2005
sorry to hear that, hope its nothing to serious
CManT1914
3,172
Killeen, Texas
Jul 24, 2005
  • Jul 24, 2005
I'm wondering if driving the car while it had air pockets in the coolant system maybe blew it. That's when I noticed the white smoke that once. It was when I was driving it before burping the coolant and when it got hot.
WhiteDevil
2,717
San Diego
Jul 24, 2005
  • Jul 24, 2005
I dunno, about that but maybe. What was the TQ sequence you did on the heads?
CManT1914
3,172
Killeen, Texas
Jul 24, 2005
  • Jul 24, 2005
From the inside out, 35/70/100 ft/lbs. I found out later I think they were only supposed to be torqued to 75 ft/lbs.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 24, 2005
  • Jul 24, 2005
You went 100 ft/lbs with arp head BOLTS??????
Follow the ford torque sequence. You can go 60-70 ft/lbs with arp bolts with their moly lube on the uppers and thread sealent on the lower.
I hope your taking those heads to the machine shop to check the deck surface and have them clean up milled if needed.
I went 35, 55 and 70 on my arp head bolts using arp moly lube on the upeprs and permatex thread sealent on the lowers. Read this spec page please: http://www.hardcore50.com/technical_articles/cleances&torque_specs.htm
95CobraMike
1,046
Lima OH
Jul 24, 2005
  • Jul 24, 2005
need help doing the HG's?
i am almost a professional
HGFireHazard
460
Michigan
Jul 24, 2005
#10
  • Jul 24, 2005
  • #10
It's always something isn't it? Head Gasket, what a pain.
RIO5.0
6,892
N.H.
Jul 24, 2005
#11
  • Jul 24, 2005
  • #11
Ahh yes..the learning curve as Mike says...it sucks and we all been there... :damnit:
Reefing them like that and air pockets in the cooling system and add some heat... Look on the bright side....head gaskets are cheap money and look at the practice your getting...
My bud just spent the last 8 yrs doing a ground up resto on a 70 SS Chevelle....mildly built 396....he get's no more than 20 miles on it and its running like ass and real noisy in the valvetrain....he tears into and finds a valve loose...Cool...problem solved....NOT...drives to the end of the driveway and its way noisy again....he tears the VC's off it....and notices 1 valve is just barely lifting when cranking it over....Long story short...His Summit cam takes a dump and loses a complete lobe off it and eats the bottom of the lifter to boot..... complete teardown shows the crank got scored, oil pump is junk...$500.00 and 2 weeks later she's back....and this guy knows his chit..
Like I say...We all been there....
blksn955.o
3,263
st.louis mo 314
Jul 24, 2005
#12
  • Jul 24, 2005
  • #12
Also might want to check the lower intake gasket, it could leak from one of the coolant ports and down into the pan. My bronco suffers from a crappy intake gasket like this but its only a slow leak (most of it evaps unless it sits, then it gets below the leak and stops).
Did you put rtv around the coolant passages on the gasket (both sides)? I have my ARP head bolts to like 75-80 and 85-90 (cant remember the exact number) on my heads and thats what fel-pro/ARP/Ford said.
cavscout371
277
#13
  • Jul 29, 2005
  • #13
That sucks man I was hoping to come back from leave and hear that you had everything finished.
I used arp ones and went 70 on the uppers and 60 on the lowers with them soaked in oil.
See if you cant get a hold of mo_dingo I know he had a similar problem when he did his and it turned out to be something other than HG's.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Jul 29, 2005
#14
  • Jul 29, 2005
  • #14
Could also be a lower intake gasket leak. I'd verify that before pulling the heads.
M
MarkFJ40
44
Calgary, Alberta, Canada
Jul 29, 2005
#15
  • Jul 29, 2005
  • #15
Make sure you do a real good job of cleaning the anti-freeze out of the engine.
Anit-freeze is great for spun bearings.
ROLLIN5.0
135
Tulsa, OK
Jul 29, 2005
#16
  • Jul 29, 2005
  • #16
Exactly. Once you get the HG's lined out. Put some cheap oil in the car, and let it run for about 30 minutes, and then change it again. I would do it more than once. I knew quite a few people with Thunderbird SC's (notorious HG failure) that would change the HG's, and spin a bearing within a month afterwards.
Brandon
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 29, 2005
#17
  • Jul 29, 2005
  • #17
you also need to check and make sure your leak is not from the timing cover or lower intake.
Either of those could be your leak. Don't condemn the HG just yet, unless you do a leakdown test and it fails, then you know your HG's are bad.
Scott
CManT1914
3,172
Killeen, Texas
Jul 30, 2005
#18
  • Jul 30, 2005
  • #18
Yea I was just going from what the instruction packet said for 1/2" bolts (although I don't remember now what size bolts they even are). I found out later that it was supposed to be 75 or so.
I pulled my lower intake off last sunday before I went to the coast, and they got thrown away I think while I was gone. :damnit: So I don't know if that was leaking or not.
EDIT: Another thing, last time I checked, I had around 145psi compression on all cylinders.
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
VE Table Not Dialed? Send Me Your Datalog.
  • X-cam34
  • Feb 8, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum May 1, 2026
X-cam34
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
