Bleeding my power steering is not working
  • Thread starter Thread starter NewToFord
  • Start date Start date Oct 24, 2010
N
NewToFord
318
CT
Oct 24, 2010
  • Oct 24, 2010
I recently put my car back together. The power steering pump was taken off as well as the steering rack. The steering on the car was super tight after this. I started the car a bunch of times and then read that I have to jack the car up and turn the wheel back and forth. Yesterday I did that. I took the cap off of the power sterring pump. I could see alot of big bubbles coming out of the pump. I must of turn the wheels back and forth 40 times. I kept seeing big bubbles. Put the car back down and now the steering feels more tight. Any suggestions? Did I do this right of do I have to keep bleeding it?
2000xp8
SN Certified Technician
Aug 8, 2003
8,067
1,654
194
NJ
Oct 24, 2010
  • Oct 24, 2010
I never jacked the car up to get the air out.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 24, 2010
  • Oct 24, 2010
Does your pump have any pressure?
Jacking the car up saves you from scrubbing precious rubber off the tire treads.
At1Maverick69
220
San Leandro, Cali
Oct 24, 2010
  • Oct 24, 2010
The way that usually works for me specially for our ford pumps is when I turn the steering wheel all the way to one side and just keep it there, that's when the pump works the hardest.
Do you have good pressure? And I'm not sure if this is gonna help at all, but I had heard a million times that friction modifier help a lot too. I tried it on my car, and the only difference I feel/hear is that there is a lot less whining from the pump.
MFE92
1,094
373
124
Phoenix
Oct 24, 2010
  • Oct 24, 2010
The pump has to be turning while you turn the wheels back and forth. But you don't want to run it as fast as when it's running. So here's what you do:
Jack the front end up
Top up the reservoir
Turn the key to run, FLOOR THE GAS AND HOLD IT. Don't release the gas. This triggers "clear flood" mode and the fuel pump won't run, so the car won't start.
Turn the key to "start" and crank it for several seconds as you gently move the wheel from end to end.
Release the key, release the gas
Lather, rinse, repeat.
You don't want to hold the wheel full lock in either direction while the pump is running.
N
NewToFord
318
CT
Oct 26, 2010
  • Oct 26, 2010
How do I tell if the pump has pressure? Also I am guessing that the cap has to be off the pump? And should I be looking for big or little bubbles?
N
NewToFord
318
CT
Oct 27, 2010
  • Oct 27, 2010
anybody?
MFE92
1,094
373
124
Phoenix
Oct 28, 2010
  • Oct 28, 2010
Leave the cap off and don't look for anything, just follow the instructions.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
  • Mindseye007
  • Aug 16, 2026
Mindseye007
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
P
Suspension 88 GT- trying to diagnose power steering issue
  • pindude80
  • May 26, 2024
Fox 5.0 Mustang Tech May 27, 2024
AeroCoupe
